Trying to ID a transmission from 1985 Chevy truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-07-2012, 06:14 PM
i have a transmission out of a 85 chevy truck that has a four prong plug on the driver side of the casing what is it and is it and over drive transmission
Old 02-07-2012, 06:22 PM
tnsmith10's Avatar
when will it rain???
yes, that should be a 700r4 and it is an overdrive trans. does the shift indicator show a "d" with a circle around it and then d-2-1? and is the pan shape rectangle?
Old 02-07-2012, 07:46 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
yep 700r4 was the only overdrive offered.
Old 02-11-2012, 02:14 PM
SSedan64's Avatar
85 could be TH350C or TH700R4, both have the 4-Pin plug for Lockup TC.
Look at the Pan shape >> http://www.maliburacing.com/auto_tranny_id.htm
1 Aluminum Powerglide 14 bolts
2 TH200 Metric 11 bolts
3 TH350 13 bolts
4 TH400 13 bolts
5 TH200-4R 16 bolts
6 TH700-R4, 4L60, 4L60E 16 bolts
7 4L80E 17 bolts
Old 02-12-2012, 12:40 PM
Nailhead2x4's Avatar
the pan will tell easily as per the post up above, also another way is just look if it has a modulator valve pointing backwards on rear right side then it is a 350C , no mod valve then a 700 o/d.
...I'm just an old rock 'n roll Hot Rodder...
98 chevy truck transmission issue chevymartin Transmission - Rearend 1 12-26-2011 05:27 PM
1985 chevy truck dual tanks aarias-31 Engine 2 05-16-2011 02:50 PM
trouble with my 96 chevy truck transmission inquiring_mind2 Transmission - Rearend 3 02-26-2011 05:27 PM
1985 Chevy Short Bed Truck 1931 steve Hotrodders' Lounge 5 09-13-2005 09:57 PM
1959 chevy truck transmission tony00 Transmission - Rearend 7 10-26-2004 10:37 PM
