trying to identify a flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2013, 07:34 PM
no.2331205
176 teeth
uses 11" pressure plate
width is 14"
I was told it was for a pontiac 400 or 455
The center hole is to small for the crank.
Told second it might be for Buick 455 Stage I or Stage II
Anyone have any specs. or info.
Old 03-03-2013, 03:01 PM
Sorry, can't say WHAT is it. It's NOT a Pontiac. Pontiacs have 166 teeth.
Jim
Old 03-03-2013, 03:15 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by transamguy View Post
no.2331205
176 teeth
width is 14"
IIRC Pontiac '55 to around '59 or so used a 176 T FW, it's around 14-1/2" diameter, maybe a little bigger.
It may be an early Caddy. Like back in the 331 ci era. Center hole diameter for the Cad FW is 3-3/16", but that's smaller than a Pont (2-1/2"-2-3/4" depending on year/displacement), so if I'm reading your post correctly, this wouldn't be it.
Ford uses a 176 tooth FW, too- but you'd see a Ford number on it.
176T Cad FW:
Old 03-04-2013, 08:10 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Dept. of corrections
Originally Posted by cobalt327 View Post
Center hole diameter for the Cad FW is 3-3/16", but that's smaller than a Pont...
Obviously this should have read:
"Center hole diameter for the Cad FW is 3-3/16", but that's LARGER than a Pont..."
My mistake.
FLYWHEEL question: t-5 (V8) and 4.3L 5 spd flywheel boneyard Buick Transmission - Rearend 1 07-20-2009 09:43 AM
1-piece sbc flywheel vs LT1 flywheel curtis73 Engine 2 12-02-2007 05:02 PM
Please Help Identify riesman20 Engine 1 09-15-2007 10:32 AM
FLyWHEEL QUESTION. 4.3L 5 spd flywheel work in t5 with clutch? boneyard Buick Engine 0 11-17-2006 07:20 PM
Help me identify this.......... 53_belair Transmission - Rearend 2 11-09-2006 09:17 AM
