trying to identify Holley carb from numbers - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2008, 12:25 PM
Last journal entry: Better late than never
I am looking to get a rebuild kit for my Holley carb but struggling to confirm the exact model.
It is a double pumper with the following numbers:
3310-9 on the side of the main body, on two lines as shown to the left here.
1832
P-36 Holley on the opposite side
8493-A on the front
8494-A on the rear. the second 4 is hard to read but I am sure it is 8494
6R-8026 on the top of the main body
Many thanks for any help,
Paul
Old 04-04-2008, 12:39 PM
The 3310 is a vacuum secondary carb. Does your carb have two pumps, one underside both bowls? Can you post some pics?
Old 04-04-2008, 04:07 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
A Holley# will start with List- then 4 #'s it is usualy stamped into the front of the air-horn
Old 04-06-2008, 06:29 AM
stroke, I read your post and sure enough you are right in that there is only one fuel pump.
I took it to the local speed store and got a renew kit which I installed yesterday. The car fired instantly upon installation and runs like a champ, very responsive. All I need to do know is work out how to set the mixture. I grabbed the Holley book on the 4160 carb (which it apparently is) and will read it today to get direction on setting mixture.
The carb had lots of tiny light brown flakes. If I had to guess I would say crystallized gas? The car has sat for 5 years and only been run maybe half a dozen times during that period.
I have flushed the tank and piped and it has fresh gas so the carb was the last thing that needed cleaning.
Thanks for your input,
Paul
Holley (ProForm) Carb Problem leejoy Engine 29 04-01-2011 11:36 AM
Holley carb problem crusherdbuzz Engine 3 07-09-2006 03:12 PM
Help!!!!! holley carb numbers will_53 Engine 3 07-07-2006 02:09 AM
Holley Carb. Question crusherdbuzz Engine 2 07-02-2006 03:25 PM
Holley carb & powervalve info Frisco Engine 9 06-25-2003 01:47 AM
