trying to put fairmont ghia digital dash in mk5 cortina - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2011, 08:51 PM
I am trying to replace my stuffed mk 5 1980 cortina dash with a 1991 fairmont ghia digital one.
Both have rev counters as my cortina is the 2.3 V6 model it just hard trying to work out how if possible to have all the other features on the "91" dash hooked up as well such as boot and door open senses fuel level sensers and little bit annoying(hopefully not expensive) things like that.
If anyone in knows of anyone who has tried this and found that it could'nt be done can you please let me know
Old 10-26-2011, 02:28 PM
vicrod's Avatar
life is a ride
Last journal entry: 2014
I can only suggest that you will need the computer module and cables that were used with the dash. The gauges won't work without the drivers in the computer module.
If you have assess to the donor car obtain as many of the sensors as possible.
If possible adapt these sensors to the car.
Oil pressure and water temp. sensors would be a piping issue.
If a sensor cannot be adapted then measure it's range. For example fuel level will be a resistance difference from empty to full.
Before installing the dash try to mock up all the inputs with the correct sensor.
Door indications are a simple switched input to the module.
Also invest in a shop manual for the donor car to show the electrical schematics for all the sensors and inputs.
vicrod
Thanks for the help with my digital dash. jvgrago Electrical 1 06-25-2008 11:53 AM
Digital Dash? Super Nova Interior 2 08-08-2005 08:10 PM
S-10 Digital Dash questions 29 2dr sedan Electrical 4 10-26-2004 01:43 PM
Corvette digital dash woody51 Electrical 2 09-18-2003 04:48 AM
