Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - trying to put on new valve seals SBC 350
Old 09-23-2007, 06:52 AM
Ed ke6bnl Ed ke6bnl is offline
Originally Posted by sbchevfreak
What I like to use instead of air is starter rope. I use about 6' of rope, and back the piston down a bit (by hand). Then I feed the rope in through the spark plug hole, and rotate the engie up by hand until it stops. This way the valves are physically unable to drop, so if the air hose gets disconnected, who cares.
I have done that with small lawn motor engines to remove the flywheel nuts. may have to give that one a try, no chance of getting the rope stuck and hard to remove?? thanks Ed
