Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
#1
Alittle1
127 edits
#2
Powerrodsmike
113 edits
#3
Techinspector1
103 edits
#4
Oldguy829
80 edits
#5
Chevythunder
50 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 12-29-2005, 09:21 PM
RedFoxRidge RedFoxRidge is offline
Trying to put together a real super duty van
Hello Everyone, I've been reading all the great posts on this forum. All this information in one location is amazing and very welcome. I have a question... I'm trying to put together what I would consider a true super duty van. The engine stuff is pretty straight forward. The transmission is what gets me. For a while now I've been considering taking the two speed rear-end out of a 1960 Chevy C-60 truck becuase it's the only thing I could think of to get the gear ratios that I need for towing and everyday driving. I've been using the van to tow a trailer full of hay, not a huge trailer. But every now and then the van is really straining to the load moving in some of the fields that I have to get the hay from.
My question.. My brother said that I can put a manual trans behind my regular trans and use it as range selector. Has any one ever heard of this? If so, what do you think?
BTW Ford E-150, 302 V-8, C-6?.
Thanks Everyone for all your posts!
AdamL
Old 12-30-2005, 05:44 AM
darrin26 darrin26 is offline
my advice
i think you should have a bigger engine... when you do alot of towing you need more torque... and the only way to get good low end torque is a bigger engine.
Old 02-05-2006, 04:12 PM
hipo225 hipo225 is offline
advice
More gearing will get you going but be gentle or you will break axles/ujoints.
Yes you could use a manual tranny behind your auto. -same idea as a underdrive-overdrive just take out gears 1,2, reverse use 3rd as underdrive and 4th as direct. You will have to mod. you driveshaft[s]
Old 02-05-2006, 05:27 PM
DuPlex tranny
Thanks Hipo225, would you think that the auto trans would soften it a bit? Although I could probably still rip the rear end out if I tried.
It seems to me that I should leave all the gears in the second tranny. Just put to gether a shifter that I can reach while driving. That way I can adjust the how slow I need to go.
Has any one seen it done?
Thanks,
AdamL
Old 02-05-2006, 05:49 PM
re: Trying to put together a real super duty van
the removal of the extra gears will save weight and eliminate grabing the wrong gear
lots of old and new truck tractors used 2 transmissions one main with an auxiliary behind it
Old 02-05-2006, 05:52 PM
matt167 matt167 is offline
 matt167's barnstar
Wiki Edits: 19
Plymouth Champs used a range selector box, that was high and low, they were FWD but same concept, don't see why it would not work if you can get a tranny cheap enough. you should leave the reverse in tho, because reverse is a low gear ( a little lower then first ) so if you need a really low gear, you shift your truck into reverse and the trans in reverse, it should make it go forward, but giving you a double low gear, or what most would call a granny gear
Old 02-05-2006, 06:00 PM
reverse gears are weak stay away
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Trying to put together a real super duty van"
Super 40 vs 50 Series Delta Flow dannimo Engine 3 01-27-2004 02:16 PM
Ford's Super Heavy Duty Transmission Capacity sum87mustang Transmission - Rearend 1 04-12-2003 02:33 PM
455 Super Duty vs. normal ??? Jared Engine 1 04-03-2003 01:25 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
