trying to upgrade a quadrajet - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2006, 11:46 PM
I have a 56 chev car 4-speed 350 flat top pistons comp 274 cam,headers,373 posi rear end.I have a quadrajet I am trying to make run above 5500.It just acts like it runs out of fuel otherwise runs good.I have a comp series carb that will run up to about 6000 so I know it is getting enough fuel to the carb.The reason I want to fix the quadrajet is it has a lot better drivability on the street.The carb no is 17057213. It has 72 primary jets and 39b metering rods,It has secondary metering rods of DG.It has rod hangar of H.I hope somebody can give me some ideas on this.I was thinking about putting 75 primary jets.and a high performance needle and seat.I am sorry this is so long so I thought maybe someone with quadrajet experience could help me thanks phil
Old 04-07-2006, 10:54 AM
Comp 274?
Now the Comp 270 has a power range 1800-5800, but I think you need to stay about 4-500 rpm under max rpm on shifting to get max power.
Old 04-07-2006, 11:24 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Q jet's are notorious for having small bowls and running out of fuel. Try upping the pressure or increaseing the Volume with a bigger needle and seat. See if you can grind way anything that will increase the bowl volume.
I see this happen to dirt racers on q jet's. They just don't like big engines at 7000 for extended periods.
Old 04-07-2006, 02:25 PM
Hippie's Avatar
Last journal entry: HEI comparison.
Don't go crazy on the pressure, the needle and seat won't hold after about 9 Lbs. if IIRC but maintaining steady pressure is important on a Q-Jet. One trick to increase fuel volume is to add a screw in fuel filter housing from an early 70's Q-Jet. I think it was mostly found on Buick's and Cadillacs. These screw in where the fuel line fitting normally went and are about 2 inches long. Leave the filter out and run an in line filter, this creates a small reservoir just outside the main fuel well. If you don't have Doug Roe's book on Rochester carbs buy a copy NOW, you'll be glad you did.
Old 04-08-2006, 03:07 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Wait. The carb is a 750. Its NOT running out of fuel. The pump (provided its operating properly) and bowls (provided the floats are set right) are more than capable of supporting a 350 to 5500. I have a Qjet on a 467 that I spin to 5800 every day and its more than enough.
The carb doesn't determine your RPM range. The cam, heads, and compression do. You can put a huge race carb on that engine and it won't rev any higher. Its totally pointless to rev this engine above the cam and head's power band, which in this case seem to end at 5800.
Old 04-08-2006, 07:29 AM
Hippie's Avatar
Good point Curtis, never overlook the obvious which we did. Have you checked the float level and read the plugs? It might be as simple as too low a float setting or you may need to make a jet, metering rod and/or hanger change.
Old 04-08-2006, 11:41 AM
Jmark's Avatar
I agree that the Q-jet should support sustained runs above 5 grand, but i've also noticed that some of the needle and seat sets in some kits leave much to be desired. The seat that has 2 slots cut in the side of it does flow more fuel into the bowl. The ones that are solid and only lets the gas flow up and around the needle seem to give problems in a high flow situation. Also, i personally like to get rid of the small filter that is behind the fuel inlet and instead run a good brand name 3/8" inline filter right before the carb.
You can also order a bigger needle and seat from www.carbs.net if you feel you still need more fuel. Just be careful because the bigger the needle area is, the more apt it is to give up under higher pump pressures. Qjets usually do just fine with an inlet pressure of 3-5 pounds with a clear filter.
Mark
Old 04-09-2006, 04:12 AM
You can also open up the float bowl into those two half inch holes at 11 and 1 o'clock(looking from above) to provide about 30% more area.
Old 04-09-2006, 05:09 AM
Twistedwrench's Avatar
No officer I won’t do it again
Mark
Just wanted to say thank you myself for that link. For two weeks I have been trying to find the gm part # 78035142 .136 needle and seat. I have had no luck. The original part number has been discontinued and changed over. I have tried the local dealership and all the parts stores around me with no luck. This was supposed to be the best one out there for the Qjet providing extra fuel flow into the bowl. Not only does that link have it but they have even a better one! You just made my day! And as to the original question on the board. I would go for this same needle and seat. Part # C1980 .147 inlet. ( but let me get mine first in case they run out!) lol
Old 04-09-2006, 06:37 AM
These would be the secondary accelerator circuit wells, removing the dividing wall will drastically alter the operation of the carb. It will allow the secondaries to suck way too much fuel out of the bowl through the accelerator tube.
Old 04-10-2006, 05:07 AM
I think I have qjet fixed
I ordered high performance needle and seat from Summit.I put larger primary jets I went from 72 to 75.I ordered a new sec. metering rods and a b holder.I tryed it yesterday I think it is going to work. Thanks phil
Old 04-10-2006, 12:20 PM
Jmark's Avatar
Those changes will for sure richen it up! Just make sure your fuel pressure is in line, 3-5 pounds. If not, higher pressures will overpower the larger needle and seat and flood like crazy!
Mark
Old 04-11-2006, 06:22 AM
I ran a 72 Q - jet so modified for years on a 350/muncie/3.00 9in equiped hq Holden ute (like a 70 el camino). It ran 12.68 in street trim, towed my 18 ft ski boat and got 18mpg on the highway (14/15 towing). I ran stock secondary rods and hanger, it never missbehaved or ran rich - wish I still had it.
Old 04-11-2006, 01:36 PM
quadrajet runs good on street
I looked for a long time a while back trying to find out what cfm a quadrajet was.Then one day someone talked about a web site that said qjet are 750 and I think 800 cfm.I know it runs alot better than my 750 carter afb on the street.They dont seem to cause a lot of drivability problems.I just had the one problem when I took it to the drags and when it hit about 5000 it acted like it was starving fuel.I later tryed the 750 carter afb and it would run all the way through the gears. So i knew it had to be the carb but I think I have it fixed now.It is hard find a place on the street to test it at 5000 onthe street in fourth gear.They might take you to jail. Thanks phil
Ignition upgrade..ur info appreciated 85GrandPrix350 Hotrodding Basics 3 03-11-2006 02:01 PM
60 Thunderbird Suspension Upgrade. 60tbirdrick Suspension - Brakes - Steering 7 08-14-2005 09:38 PM
Which Quadrajet for 67 Ram Air? 67firebird General Rodding Tech 8 12-11-2004 11:07 PM
1976 Quadrajet help needed janetdennyh Introduce Yourself 1 11-24-2004 09:10 AM
Brake / Suspension Upgrade - 75 Chevy Pickup dwstevenson Suspension - Brakes - Steering 0 12-31-2002 08:42 AM
