trying to wire a 79 fire bird - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2011, 08:54 PM
trying to find out how the car gets power,i had a 79 z28 and it had two wires from the outside wiring harness,but there does not seem to be any wires like those on the z28 .i found the wire that gos to the sylonoid just have not figured out the starter/inig
Old 10-21-2011, 04:31 AM
EOD Guy's Avatar
Really not sure what you are asking? How the starter is wired? How the charging system works? How the ing system works?
Old 10-23-2011, 08:17 AM
Finding the lead to give the car power
Somehow icant find the wire from the outside fuse block that gives the inig,head/taillights .etc.its the wire that feeds power to car
Old 10-23-2011, 02:07 PM
EOD Guy's Avatar
It should be a #10 red wire that comes from the starter lug or the alt lug or a factory splice....... not sure how yours is wired.
Old 10-23-2011, 02:46 PM
In most cases the 10 gauge wire on the starter lug runs through a metal tube behind the exhaust manifold and up to the harness behind the valve covers. In this harness there is a Y connection. The wire on one side of the Y runs along the valve cover to the alternator BAT terminal, and the other wire runs over to a terminal junction mounted on the driver's side of the firewall. Power for the fuse box runs from this junction over to the fuse box.
The 10 gauge wire has a fusible link both on the starter end and on the end that connects to the firewall junction. If there has been a short, it often burns one of those fusible links. You can buy a fusible link replacement at just about any parts store - GM 14 Gauge fusible link (which protects a 10 gauge wire).
Bruce
Old 10-24-2011, 03:53 AM
EOD Guy's Avatar
The fusable link is orange and should be 6-10 inches long spliced to the #10 red wire
engine swap 454 bb to 1981 fire bird timboo Hotrodding Basics 3 08-22-2011 06:38 PM
Ground wire on fire... south65ss Electrical 10 06-16-2010 08:18 AM
found a 64 fire bird rtyauch301 Hotrodding Basics 26 01-11-2010 03:12 PM
Fire Bird 1986 JamieTazz Introduce Yourself 1 05-21-2007 10:19 PM
92 5.0 HO T-bird wire harness help NDNslicks4me Electrical 4 07-20-2005 12:15 AM
