TT '25 1 ton steering - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-17-2002, 08:50 AM
Post TT '25 1 ton steering
Should I use a Vega or Mustang steering box in my model T truck? I'm gonna have to run the pitman arm to the outside of the frame because of space restrictions due to using s/b chevy. Mike
Old 12-17-2002, 02:13 PM
Frisco's Avatar
Glad To Be Here
Post
[quote]Originally posted by bowwy:
<strong>Should I use a Vega or Mustang steering box in my model T truck? I'm gonna have to run the pitman arm to the outside of the frame because of space restrictions due to using s/b chevy. Mike</strong><hr></blockquote>
Since you are going to run side steering instead of cross steering the only choice you have of the two you listed is the Mustang. If you go with that box, use 4-bar radius rods ONLY or it will have some serious bump steer problems. A third choice that will work excellent with any style radius rods is a mid 50's Ford F-100 box.
[ December 17, 2002: Message edited by: Frisco ]
[ December 17, 2002: Message edited by: Frisco ]</p>
