Tubbed rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2002, 11:56 AM
Burnin ruber...raising hell!
Post Tubbed rear end
I have a 63' Impala SS i talked to a guy that said i will not need to get new frame rails or a cross member, he said that he could make them out of the frame i already have. I was wondering if i should do it this way or just get a kit? what is your guys oppinions? thanks..
Old 05-17-2002, 05:00 PM
Thumbs up
That would be a matter of dollars,it would definitely be cheaper using your old frame,Ive seen it done on a 66 chevelle and it looked good.thats how Im going to do mine when I get around to it.It sure a lot cheaper using your old frame.(Just my opinion wrenchturner)
Old 05-20-2002, 10:44 AM
Post
ok thanks for the tip... but i still think that i am goin to get a kit i saw in the jegs catolog. it is 2 hundred somthin for the frame rails, cross member and the mounting for the 4 link. I think that i am goin to get mine done somtime in july.. because i am goin to send off for the stuff now and when ever it gets here is when i am goin to start doin it... i hope.
Old 05-21-2002, 08:15 PM
HotRodS10's Avatar
All Throttle...No Bottle
Thumbs up
Hey 409Guy.....before you order that kit you might wanna check with jegs and make sure its gonna fit right without a whole buncha modification and find out everthing your gonna have to buy to make this thing work. Check out www.swracecars.com, they offer frame kits for varius cars/trucks and include the ladder bars, shock/spring kit and all suspension mounting hardware. Its worth a look , Good luck...HRS10
Old 05-21-2002, 08:19 PM
HotRodS10's Avatar
Thumbs up
Hey, the above link will not work because of comma at the end of the sentence. Try this one www.swracecars.com
Old 05-21-2002, 09:45 PM
Post
hey man thanks for the link. Thw one that i saw in jegs is the same kit, exactly. except the one in jegs does not come with the springs or theaxle housing and it is $600 cheaper. but now i am kinda wonderin what size tubs i should go with. i think that the ones i saw in summit said they were 36 inch wide but that seems huge so i might of read that wrong, plus i would only have 4" of space between the tubs. well thanks again man, and if you can think of anything else about tubbing a rear end tell me thanks..
