Originally Posted by Onebad79malibu
Hey all!I began to start cutting the sheet metal out for my tub job.I guess I didn't realize the support bars for the rear end were bolted to the sheet metal in the floor board in front of the back seat.So the sheet metal has to be cut back to where the frame is parallel with each other before it curves underneath and rises for the shock and spring mounts?????ive got a sheet metal brake so I can fabricate a new driveshaft tunnel if I have to.Am I correct in this way of thinking???Thanks guys!!
We need pictures to say what to do on THAT car..Without seeing it, it's hard to say for sure.. Post pictures and it will be easier to say..
Here's a Mustang I did..Might give you some ideas..The four bar came right off that crossmember..
