Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tubbing my Malibu
  #61 (permalink)
Old 02-02-2013, 08:27 AM
1971BB427's Avatar
1971BB427 1971BB427 is offline
Originally Posted by Onebad79malibu View Post
Hey all!I got my wheels under the car where they need to be and determined after several measurements,I determined my rear end needs to be 43 1/2 inches from WMS to WMS,which means I need to shorten my rear end by 11 inches.I am sending the axles off to get them cut down,I have strange c clip eliminators welded on,so I'm assuming when moser cuts the axles down they will just eliminate the groove for c clips,and if they measure from the splined end of the axle,will the 5.5 inches start at the very end?is this the correct way of thinking??maybe I'm over thinking but I don't want to send them in twice
"Welded on"??? I've never seen them welded. My Strange c clip kit bolts on, and is aluminum, so not sure how they could be welded to steel backing plates?
As for the axles, you have the housing tubes and axles cut the same amount.
