Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tubbing my Malibu
  #65 (permalink)
Old 02-02-2013, 09:09 PM
1971BB427's Avatar
1971BB427 1971BB427 is offline
Originally Posted by Onebad79malibu View Post
Yes I have all the parts just not on in the picture.I took the kit and the rear end to a local shop and had it installed.I just assumed they knew what they were doing since I've never had any problems with it.this is the first time I've had it apart since it was done over 2 years ago.
It's still salvageable, if you have the inner half of the housing. The weld can be faced off in a lathe when they cut the axles down, so that would fix the welded sleeve issue. The bearing should be a press fit, so welding a retainer sleeve on is not needed.
