Tubbing my Malibu - Page 5 - Hot Rod Forum : Hotrodders Bulletin Board
  #61 (permalink)
Old 02-02-2013, 08:27 AM
1971BB427's Avatar
Originally Posted by Onebad79malibu View Post
Hey all!I got my wheels under the car where they need to be and determined after several measurements,I determined my rear end needs to be 43 1/2 inches from WMS to WMS,which means I need to shorten my rear end by 11 inches.I am sending the axles off to get them cut down,I have strange c clip eliminators welded on,so I'm assuming when moser cuts the axles down they will just eliminate the groove for c clips,and if they measure from the splined end of the axle,will the 5.5 inches start at the very end?is this the correct way of thinking??maybe I'm over thinking but I don't want to send them in twice
"Welded on"??? I've never seen them welded. My Strange c clip kit bolts on, and is aluminum, so not sure how they could be welded to steel backing plates?
As for the axles, you have the housing tubes and axles cut the same amount.
  #62 (permalink)
Old 02-02-2013, 09:02 AM
Tubbing my Malibu
This is what I meant by being welded.Im not sure the pic will be right side up.
  #63 (permalink)
Old 02-02-2013, 10:09 AM
1971BB427's Avatar
Yikes! Why would somebody do that? Don't you have the inner half to the Strange bearing housing? There's supposed to be two pieces, and the inner half holds the bearing in place, so no weld is needed. Looks like someone did some backyard repair to that, and it will make bearing changes a real dilema in the future!
  #64 (permalink)
Old 02-02-2013, 10:20 AM
Tubbing my Malibu
Yes I have all the parts just not on in the picture.I took the kit and the rear end to a local shop and had it installed.I just assumed they knew what they were doing since I've never had any problems with it.this is the first time I've had it apart since it was done over 2 years ago.
  #65 (permalink)
Old 02-02-2013, 09:09 PM
1971BB427's Avatar
It's still salvageable, if you have the inner half of the housing. The weld can be faced off in a lathe when they cut the axles down, so that would fix the welded sleeve issue. The bearing should be a press fit, so welding a retainer sleeve on is not needed.
  #66 (permalink)
Old 02-04-2013, 06:00 PM
Tubbing my Malibu
Hi all!Finaly got my rear end cut down to size and got the axles sent off to be cut to size and re-splined.Im posting some pics but I'm sure they won't be right side up,still haven't figured out why.
  #67 (permalink)
Old 02-04-2013, 06:02 PM
Tubbing my Malibu
Another pic
  #68 (permalink)
Old 02-05-2013, 07:56 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Looking good so far..
Just make sure you leave a little room between the lip of the fender and the outside of the tire,, Also on the inside too..
  #69 (permalink)
Old 02-05-2013, 08:06 PM
Tubbing my malibu
Thank you.With the back spacing on the wheels and the length of my rear end I'm going to have about 2 inches from the closest part of the 1/4 panel.Hopefully my axles will be back next week and I can move on to installing my frame rails.Im keeping my fingers crossed that I can find some coil overs at the swap meet next weekend.Im hoping to at least be able to get it on the road by spring though I'm sure it won't be painted yet.
  #70 (permalink)
Old 02-06-2013, 08:36 AM
1971BB427's Avatar
I like the way the tires sit. Not too far in like some tubbed cars.
The Following User Says Thank You to 1971BB427 For This Useful Post:
NEW INTERIORS (02-06-2013)
  #71 (permalink)
Old 02-06-2013, 09:45 AM
Man !!!! I can't understand why you stand on your head to take these pictures...
Just pulling your leg a little..
Look's great from my end..
ID:	71126   Click image for larger version
ID:	71127   Click image for larger version
  #72 (permalink)
Old 02-06-2013, 11:42 AM
Tubbing my Malibu
Thank you.I don't like the look either of the tires tucked too far underneath,just doesn't look right.Hopefully ill get some new upside down pics up soon,work has been busy and just haven't had time to go play in the garage.Ive got my steel in the garage just waiting on axles to arrive so I can determine frame rail location once rear end is together and mocked up in place
  #73 (permalink)
Old 02-15-2013, 06:46 PM
Tubbing my malibu
Hi all!Sorry but I had to use a different email address.I am back on my project and starting on my frame work.I have the cross member welded in and boxed in the ends of the existing frame where it was cut.went to the swap meet today but I didn't have any luck finding an affordable 4 link set up.I found them on line cheaper than what they were at the swap meet.Ill post pics when I get a little farther along.Thanks everyone!
  #74 (permalink)
Old 02-15-2013, 07:01 PM
1971BB427's Avatar
Speedway Motors sells a pretty decent kit for $350.
Heavy Duty Rear Four-Bar Kit - Speedway Motors, America's Oldest Speed Shop
  #75 (permalink)
Old 03-24-2013, 03:31 PM
Tubbing my Malibu
Hello everyone!!Its been a while since I've posted so I thought I would catch you up and even post some upside down pics :-).Work has been crazy so not much time for the project but I have managed to fab crossmember and get one frame rail tacked up.Ive purchased my 4 link kit and coil over shocks so I could begin mocking everything up.I haven't got the rear end all put together yet,I figure I can do all that once my frame rails are complete.Its been a LOT of work just taking all the measurements and getting everything laid out.I also got my wheel tubs mocked up out of cardboard.Hopefully someone can rotate the pictures if they don't come out right.Thanx everyone and if anyone has any suggestions or advice for this stage in the game,feel free to post,good or bad.
tubbing back half
Tubbing CRJ-72 Hotrodding Basics 1 01-31-2010 08:49 AM
tubbing jagking Hotrodding Basics 6 01-23-2010 11:52 AM
tubbing a 64 falcon? falconpro General Rodding Tech 3 10-04-2004 10:09 AM
Tubbing a GM 12 bolt toooofastforu Transmission - Rearend 5 09-22-2004 06:35 AM
tubbing custom 55 Suspension - Brakes - Steering 1 06-19-2003 10:35 PM
