9" is the way to go. To tub it you will have to narrow the frame,so depending on what suspension set up you use the fuel tank will have to be moved.Most put a fuel cell in the bed.
The 9'' is a very good rear end to use.You will have to buy the motor mounts,And headers to fit in that truck.I had a pro street Chevy luv with 18.5 tires under the back.And 456 gears.It would fry the tires as long as i would want too.very fun truck I miss it.Pic in my album of the luv.
This is a race only truck and is not streetable. It already has a fuel cell in the bed and the stock tank is gone. You just have to narrow the frame from a point between the transmission & rearend to allow for bigger & wider tires, right? Will the 9" have to be narrowed also?
Thanks |
yes.
89 S10 should have the 7.5" so its REALLY not stout enough. I only say that so you don't drag your feet on the swap... like don't say to yourself, "I can limp the factory axle along for a while." cause you can't
Within a week of installing a 300 hp LS1 in his, my buddy's 7.5" went with a bang just pulling out of his driveway.
I have an s10 with a smallblock in it. I put a ford 9" in it out of a late 60's/early 70's bronco with out shortening it. It is a little wider than the factory s10 rearend. I just compensated with different offset wheels in the rear.
| S10 to '49 Olds? | grouch | Suspension - Brakes - Steering | 100 | 10-22-2010 03:57 PM |
| S10 truck transfer cases - 4WD to AWD | curtis73 | Transmission - Rearend | 6 | 04-17-2007 02:22 AM |
| S10 frame help. | matt167 | Suspension - Brakes - Steering | 15 | 07-28-2006 07:10 PM |
| S10 pickup or S10 Blazer frame? | raj4851 | Hotrodding Basics | 10 | 01-06-2006 09:28 PM |
| V8 S10 | 89SDime | Transmission - Rearend | 9 | 02-19-2005 03:54 PM |
