Tubbing an S10 - How Much????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-29-2007, 08:53 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
I have an 89 S10 that I am considering tubbing for some wider slicks. This truck is a drag race only truck so streetability is not a concern. My question is, does anyone know how much I would need end to narrow the rear for a tub job? I know it depends on how wide of a tire I want to run but I am looking for someone that has already done this and get their opinion on what works and looks the best. If anyone has any pictures of a tubbing project, that would be nice to have since this will be my first time doing this.
Thanks
Old 12-29-2007, 09:02 PM
31 five window
Last journal entry: grill and rear end
I don't have any pictures but I start with buying the tires and wheels I am going to use and measure from there. The width of the rear end depends not only on tire width but wheel offset.
Old 01-20-2008, 03:15 PM
techinspector1's Avatar
Wiki Edits: 326
Agree with speedydude. Get the wheels and tires (mounted). Determine where you want the outside of the tire to be on the truck and measure that side to side. Set the two tire/wheel assemblies on the garage floor the same width you measured on the truck. Now, measure from the inside mounting surface of one wheel to the rear mounting surface of the other wheel and you have your differential width axle to axle.
Old 01-20-2008, 08:48 PM
BlownBigBlock447's Avatar
What he said...
Old 01-20-2008, 09:18 PM
Got any more pics?^
Shane
Old 01-21-2008, 08:45 AM
Originally Posted by Chevrolet4x4s
Got any more pics?^
Shane
Here's a shot or two of the rear.. What I have in my backhalf is kinda to the extreme. But a real quick breakdown. Frame rails were like $400, probably another $400 for the 4 link setup, have about the same is my shocks and springs. The rear itself is around $2000 - $2500 with brakes. Almost all of the rear suspension is powder coated. Since I don't weld to the degree that I'd be comfortable doing the brackets and cage. I think that ran me around $1600. All the tin work, etc... was just my time... A truck is a bit easier because your dealing only with a bed bodywise. Guessing I would say around $5K. For an S10 there are kits available - does make it a whole lot easier..
Old picture, redid the brakes, other odds and ends..
Old 01-22-2008, 03:05 PM
lets cut it up's Avatar
If your looking for a kit to tub your truck try s &w race cars they sell specialized kits and narrowed rears per application. There stub welds in and then you cut out your original frame after.They will tell you what size rim and tire and all. I used their kit on my 55 chevy and it worked great. You might want to take alook at their stuff . Just some thoughts, Tim
Old 01-29-2008, 03:35 PM
Last journal entry: Albany Oregon Show
Pics of a tub project
Check out my journal. I have lots of pics on tubbing.
Bob
S10 to '49 Olds? grouch Suspension - Brakes - Steering 100 10-22-2010 03:57 PM
Tubbing S10 S10 Racer Transmission - Rearend 7 01-25-2008 12:46 PM
S10 truck transfer cases - 4WD to AWD curtis73 Transmission - Rearend 6 04-17-2007 02:22 AM
S10 frame help. matt167 Suspension - Brakes - Steering 15 07-28-2006 07:10 PM
S10 pickup or S10 Blazer frame? raj4851 Hotrodding Basics 10 01-06-2006 09:28 PM
