Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated June 18th, 2009
#1
Crosley
520 edits
#2
Crashfarmer
401 edits
#3
Alittle1
295 edits
#4
Techinspector1
173 edits
#5
Powerrodsmike
157 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 03-21-2005, 03:15 PM
atlantis atlantis is offline
Tube grill
At the moment while waiting for some parts to arrive I'm thinking about how to make my tube grill. I'm planning to use 10x1mm stainless tubing (as used for water installations). The Monte's grill has an edge at the front (red line in the picture below, not my Monte btw). Do you think this can be bent into such a sharp edge? With what equipment would this be done? I'd rather avoid to cut every tube and weld it back together if possible.
Regards
Martin
Old 03-21-2005, 03:54 PM
tbirdscott's Avatar
tbirdscott tbirdscott is offline
stuff'n things'n whatnot
Fill the tubing with sand before you try to bend it or it will kink.
Old 03-22-2005, 08:20 AM
How do you plug the ends of the tubes? I have a bender which is suitable for these tubes but it is a traditional one not a mandrel therefore it tends to some distortion where the tube is bent.
Regards
Martin
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Tube grill"
Bending Tube 62slantsix Body - Exterior 15 01-02-2009 11:21 AM
327 with draft tube ??? Ed ke6bnl Engine 23 03-27-2006 08:37 AM
32-34 ford grill shell mehegan Body - Exterior 1 01-05-2005 05:13 AM
aluminum grill repair helrazr3 Body - Exterior 4 10-17-2004 02:03 PM
broken oil dipstick tube guilty1 Engine 10 01-16-2003 02:17 PM
