Tube Shock Removal Ford Straight axle - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2012, 05:27 AM
Any ideas about how to remove lower shock stud without beating it to death?
Name:	40 susp 001.JPG
ID:	69400   Click image for larger version
ID:	69401   Click image for larger version
ID:	69402   Click image for larger version
Name:	40 ford 002.JPG
Old 11-27-2012, 05:31 AM
poncho62's Avatar
Wiki Edits: 5
A bit of heat might work if you dont plan on reusing the shock. Have you got a better pic of the lower stud, nut etc?
The Following User Says Thank You to poncho62 For This Useful Post:
artistsport3 (11-27-2012)
Old 11-27-2012, 05:41 AM
Thanks for the response! The shocks have "Made in USA" stamped in them along with ALLSTATE Supramatic.......Sears? From the 60's?
Old 11-27-2012, 06:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The nut has to come off, along w/the wedge/spacer (circled below). Then the shock should come right off w/a little prying. The wedge may take a rap from a ball peen hammer to come loose.
Old 11-27-2012, 07:45 AM
Irelands child's Avatar
The shock will come off reasonably easy - the stud will not (usually). Get the shock off first, then soak the stud 1 to 24 hours in one of the 'miracle' rust releasers such as PB Blaster (WD-40 just isn't worth while anymore). Maybe hit it with a little heat for encouragement, but not to change the axle color. Regardless, you have a good chance of destroying that stud, but a BFH may be your only friend in the end. I did a couple '48 axles and that was the only way anything moved.
(Just wait until you need to remove the wishbones)
Dave W
Irelands child
46 Ford straight axle vs Mustang II rcross55 Suspension - Brakes - Steering 1 07-25-2010 05:43 PM
What length straight axle for a '33 Ford? RodFather Suspension - Brakes - Steering 4 01-15-2008 08:20 AM
'37 Ford tube axle on eBay..... SJFast Suspension - Brakes - Steering 0 10-09-2002 09:19 AM
