Hey I think it's very doable, in fact I mad a simple tool to straighten my mig wire so I could gas weld with it. But back to yours. I would make the wheels out of a hard wood and have some one or your self if equips spin them and put a groove in them. It's on the line of a circle bender but dose the opposite. The wood is easy and you could have different sizes and find different uses for it.
let me knownhownyou make out, or if y'all need to toss some ideas around. Also make sure the tube comes threw nice and straight and no twisting which will add more of a torsional twist and is harder to remove. Cheers
you can make a tool to remove coil set out of rubber casters. To groove the wheels put a caster wheel on a bolt and nut, tighten the nut down snug, then chuck in a drill and use a course round file to make a groove.
Another way is to clamp both ends of the tubing , then anchor one end to a fixed object, fasten the other end to a come-along hooked to another fixed object. Put some tension on the tubing with the come-along. Go slowly and check your progress, just enough is enough. |
straight tubing
when i was working on a job and needed st tubing from a coil. i'd cut to length and add some... hang one end on a chain fall and the other to a heavy wt.. lift it or try and it'll straighten right out by slightly stretching it... of course not everyone has a hoist 40' up... maybe hook an end to your truck and pull with a rider mower... easy !!!!!
Actually found pretty much exactly what I wanted to make on another site.
Except some guy made his tube straightener out of angle iron pieces. Instead of a piece of plate steel with slots cut in it like I had imagined. I went to two different hardware stores to find the wheel bearing 'U' grooved rollers but have came up empty handed so far. Quest continues. I'm not sure if I can post a link to the H.A.M.B on here or not so I wont. Here are some of the guys pics. ![]() In action
| The Following 3 Users Say Thank You to Rell For This Useful Post: | ||
sliding patio rollers ?
Those brass colored wheels look like replacements for a sliding glass patio door, also look similar to the rollers on a 10 in commercial grade tile saw sliding table . I used 4 on a plasma cutter trolly that rolled on angle iron for straight line cuts.
http://www.glassdistributorsinc.com/...rs.htm?cat=103 |
patio door rollers
I bought mine at Home depot or lowes for 2 or 3 dollars each, some rollers for heavy wood doors are a lot more on the web site posted.
Still at that price and for someone that has all other materials needed laying around like hardware, angle iron. You still come out cheaper then that $200-$290 tool that will do the same thing. |
Sweet tool.
You ought to submit it to the Homemade Tools section at the top of the page.
Brian |
| Tags |
| fuel line, tubing |
| Recent Garage - Tools posts with photos |
| Currently Active Users Viewing This Thread: 6 (0 members and 6 guests) | |
| Homemade hood spring tool | wretched ratchet | Garage - Tools | 1 | 10-12-2011 04:09 PM |
| Simple Homemade Tool: Flexible Pickup Magnet | oldschoolrods | Garage - Tools | 2 | 12-14-2008 10:28 PM |
| Low cost homemade welding tool. | MARTINSR | Body - Exterior | 2 | 06-30-2007 11:51 AM |
| Attention Auto Geniuses, Nairb Is About To Lose It!!! Help!!! | NAIRB | Engine | 10 | 12-11-2005 04:41 PM |
| Attention Auto Geniuses, Nairb Is About To Lose It!!! Help!!! | NAIRB | Engine | 5 | 12-09-2005 10:40 PM |
