Tubing?
Does anyone have the information on what NHRA is currently specing for roll cage and chassis tubing..??
I need to make up a steel order for my chassis and I would like to meet spec should I take this car out to the strip.. The car will probably fall into a gas altered classification something like old style BG/A or BG/SR..Might even get stuck into the pro-street class.. Thanks guys..this site has brought back a lot of good memories.. OMT
Thanks Willy
I checked that page out and sent off an e-mail for clarification of the spec..they did not say DOM or if the DREW was what they wanted..Does make a difference..
Soon as I hear from those guys I will post that info.. Thanks OMT
nhra rules
If I understand correctly. You are asking about fuel altered class. It no longer exists as it was deemed too dangerous.
The roll cage of any vehicle running 9.99 or quicker, or 135 mph or faster, must also be certified by NHRA every 3 years, and have a serialized sticker affixed prior to participation. Pro-street roll cage pictured with tubing specs attached or can be found at http://www.nhra.com/contacts/tech_faq.html |
Historical note
Now forgive me if my memory fails me here..I the early 60's we had four divisions of Nhra..stock, gas, altered and rail.
Gassers could run with a maximum of 10% engine setback as measured from the center of the front axle to the #1 spark plug hole..Altereds were allowed up to 25% engine setback..any more setback that 25% and the car was a rail.. Classifications were by engine displacement/weight break and I canot remember just what the weight breaks were..basically a big block in a lite car went into A..a small block in a lite car went into B and a heavier car would wind up being in C and so on.. There was also blown and ublown divisions and fuel and gas..A blown car had a sub designate of A and if the car ran fuel there was an F in the designation.. So we had the AA/FA blown big block alterd on fuel..and things like BG/A and so forth..that was before brackets and all the new rules.. Any way as far as the tibing order on the mild steel I need to get it figured out if NHRA has to have the DOM tubing (seamless drawn) or the rolled and welded ERW type..big difference in cost between the two and having dealt with tech in the past I do not think it woudl be good to be sent home because I somehow got the wrong tubing specification.. Thanks OMT
regs
I just grabbed that tidbit off the net. My rule book is out in the car. Will check on it. You can also email NHRA at tech@nhra.com
The gas classes were unique in that they were the only ones to differentiate supercharged from normally aspirated or injected. Thus A/GS was the top supercharged class while A/G was the equivalent non-supercharged entry. Don't know about the other classes but the weight breaks for gas classes changed up and down several times over the years.
new classes
I can't remember them all, but there is pro, super pro, sportsman, super gas, super street, prostock, stock eliminator, and comp eliminator.
Rules changes
I have not kept up with all the variations myself over the years but I do know that keeping up with the rules and staying competitive got to be a real hassle for a lot of fellows..that accounts for a lot of the former race cars setting in someones barn somewhere..
OMT
My choice
Well guys I am going with the HREW tube..that is the stuff that has a welded seam..Apparently it is legal as Art Morrison is using it for his cage kits in the 0.134 wall thickness..
Since this is more for me than for anyone else thsi is the way to go..the HREW is much cheaper as well than the DOM and 4130..well bottomless checkbok is needed for that.. Thanks for the Input guys.. OMT
Racing politics
Now there is a subject that can keep us going for a long while..arcane little rules that can be used to DQ someone..
having to completely rebuild a car from season to season to stay competitive and somewhere near to being in the rule book.. All that sort of thing has done more damge to racing than any other thing that I can think of.. OMT
Got the message
Nhra returend my message and it appears that one can use either HREW or DOM even 4130 if one desires..but then the rule requires 0.120 wall 1 3/4 for roll bar..and 0.120 wall 15/8 for roll cage..
Does not make a lot of sense to me as those are three way different specs for the same tube in the same roll cage....but oh well..Does not have to make sense to me.. OMT |
| Recent General Rodding Tech posts with photos |
