tubing bender - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2006, 12:52 AM
smoke's Avatar
tubing bender
Just picked this up for $30.00. Don't really have a use for one but I figured at that price I couldn't pass it up.
Anyone else have one like this.?
Old 12-04-2006, 01:10 AM
That is not a tubing bender!!!!!!!!!
That is not a tubing bender, it is a pipe bender. The sizes for pipe and tubing are different. Tubing goes by od and pipe uses id. 1 1/2 tubing wont fit in a 1 1/2 pipe die and vice versa.
Old 12-04-2006, 01:16 AM
Rambo_The_Dog's Avatar
Last journal entry: Shop Remodel Progress
Can't use it for exhaust but 30.00 is a great deal for the tool.
Priced out on HF 99.00-159.00 depending on size.
Doesn't take up much space and you will find a use for it!
Old 12-04-2006, 06:14 AM
BOBCRMAN@aol.com's Avatar
I have made many crossmembers and chassis parts with mine. Even bent up a few tube axles with it. Good price!
Old 12-04-2006, 07:16 AM
powerrodsmike's Avatar
Wiki Edits: 161
I've heard of guys making a liner for the dies on those benders to bring them down to a size that will fit the tube OD.
You bend a piece of pipe with the die, then cut it so it fits on the inside of the die. Sometimes you have to mess with them a little with a grinder to fit the OD of the tube. You can get a little tighter bend in a piece of thinwall tube that way.
Without the liner, they'll usually bend heavywall tube without kinking, but bending thinwall becomes a problem because the wall collapses.
Those "Y" frame benders will also do square tubing as long as you don't try to bend it in a tight radius. I've seen the square tube split a cheap die if you ask it to do too much.
I have an old greenlee model 778(?) segmented rigid conduit bender that I picked up at a garage sale for 25.00. It is the granddaddy of those HF ones. It has to weigh 7000# . I'm going to make a few dies for it someday and that baby will bend some tube! Right now I'm next door to a muffler shop with a hydraulic bender, and I have a hossfield bender, so making dies isn't a priority.
I have used it to put some shallow bends in square tube, it worked great.
Later, mikey
ID:	16598   Click image for larger version
ID:	16599   Click image for larger version
BE different....ACT normal.
Old 12-12-2006, 08:40 PM
37ford4dr's Avatar
bobs77vet
Last journal entry: frame repair
i have one of those and we bent up some pipe with it just for fun.....you can't go wrong for $30
Old 12-14-2006, 06:25 AM
low budget rodder's Avatar
This could be used for exhaust (or any other tube / pipe) but it takes a little bit of effort and a little mess.
If you get the exhaust tube and...
weld a cap on one end,
fill it with sand,
weld a washer on the other end,
weld a nut at the opening of the washer,
and run a bolt through the nut, through the washer into the pipe packed with sand (to really pack the sand in the pipe tight), then you can bend just about any pipe or tube that you could ever want without kinking.
It takes a little effort, but for the price it is almost worth the effort.
Best of luck,
Joe Ferrero
Geneseo, NY
Old 12-14-2006, 06:36 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
Just be ABSOLUTELY SURE that the sand is dry. Steam does nasty thing to human body parts, and sometimes steel parts. (Kaboom!)
Old 12-14-2006, 09:32 PM
That is true. When you are welding, weld the solid cap first, then the nut on the washer, and then that assembly (without the bolt) so there is an open end. I also forgot to mention to remove the caps before using the pipe in the exhaust or other parts that you are making.
Best of luck,
Joe Ferrero
Geneseo, NY
Tubing bender online manual 302 Z28 General Rodding Tech 37 01-23-2006 03:12 PM
Exhaust tubing expanders ease of use. 70bird Engine 4 03-24-2005 03:48 PM
tubing bender Big Rig Garage - Tools 7 12-09-2004 08:17 AM
Pipe Bender Question silm man General Rodding Tech 17 11-21-2004 04:30 PM
Tubing bender for 1/2 in. k2mooch General Rodding Tech 3 05-20-2004 10:29 AM
