If it's like this one,No it will kink the tubing/pipe.You need a mandrel bender to do roll bar tubing.
Don't know which one you are looking at, but most of the so called tubing benders from these outfits are really pipe benders. They won't do a good job on tubing because the forms won't fit the countours of tubing, Tubing and pipe have different diameters for the same size. Expect to spend 500 and up for a tubing bender, good ones over a grand.
Jd squared and pro tools make the good manual benders..and they have the dies to fit the tubing you are using..
Sam
I don't know your budget... or if you plan on doing this sort of thing more then once, but I have always been a sucker for GOOD tools, and never mine did saving for them. If I was to buy a Tubing Bender it would not be from Northern Tools, nothing wrong with Northern Tools, just not for a bender. I would look around and try places that sold professional fabricating tools like Trick Tools, they have everything from pro to beginer.
I recently purchased a bending outfit from them and they are a joy to work with, both before and after the sale. A good bender represents a huge financial undertaking, and you'll find the bigest expense is the dies, and not really the bender itself. I bought the JD2 Model 4 Bender with hydraulic power, cart and 6 sets of dies. So far the bender has worked great and is everything I wanted. Good luck with yours. Features: Hydraulic powered Easy setup and operation Self locking ratchet. Prevents material springback. Large radius degree wheel Quick change dies High bending torque over 60,000 in./lbs. Durable heavy duty steel construction Ships UPS Capacity: Round tubing to 2-1/2" (.120" Wall) Square tubing to 1-1/2" Pipe up to 2" schedule 40 and 1-1/2" schedule 80 Flats up to 3" wide and 3/4" thick |
| Recent General Rodding Tech posts with photos |
| Aftermarket EFI ? | x007 | Engine | 61 | 02-08-2012 10:38 AM |
| Power output formulas | SAATR | General Rodding Tech | 14 | 05-12-2004 08:46 PM |
| finally time to put my indian back together | bullheimer | Hotrodders' Lounge | 8 | 03-03-2004 07:23 PM |
| Alright. One more quick comp lesson 4 me | HemmiGremmie | Hotrodders' Lounge | 13 | 01-02-2003 07:14 PM |
