Tublar trans crossmember for muncie - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2006, 09:03 PM
Hi,
Does anyone know where I can find a muncie 4 speed trans tublar crossmember for my 69 camaro I like the look and I think it would be easier to install.
Thanks
Old 02-02-2006, 09:34 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Performance Automotive and Transmission Center has one. Go to the link below and look at part #49-350. This gives you a transmission crossmember with good clearance for dual exhaust.
http://www.transmissioncenter.net/gf...ssmembers_.htm
Hopes this helps.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 02-06-2006, 01:08 AM
That looks just like the original. Removing the original is easier if you jack up the tranny a bit, knock the right side forward with your fist, and knock the left side rearward. Reverse the procedure for reinstallation.
Remove crossmember? cletis Transmission - Rearend 3 02-11-2005 11:52 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 09:51 PM
TCI Trans Crossmember Bolt On for Chevy redsdad Suspension - Brakes - Steering 1 10-23-2004 01:44 PM
First time trans rebuilder...need tips! 4 Jaw Chuck Transmission - Rearend 14 06-23-2004 03:29 PM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-26-2003 12:16 AM
