tubro 400 yoke - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-17-2007, 05:09 AM
tubro 400 yoke
i have a400 with the bolt on yoke someone told me i could use a slip yoke if so what size does the yoke shaft have to be and i was told to counter bore it and then some one suggested to cut the thread part of so guys let hear some input
Old 10-17-2007, 06:52 AM
Turbo 400 yoke
Yes you can use the slip yoke. This is from the chevelle Tech site.
You can use a slip Yoke in the place of a Bolt on Yoke with no problems. The only difference is that some yokes are vented and some are not depending on output shaft groove. If it is grooved you'll need the O-ring seal to keep fluid from leaking out the vent, if you have a grooved ouput shaft and a non vented Yoke just leave off the O ring. If memory serves most converson Yokes are sealed and TH-400's with bolt on Yokes are known as TH 425's having straight cut pinion/spur gears within the planetary(=stronger). They were found in Buses, 1-2 ton Full size delivery Vans etc etc. HTH.
I say that the statement it being a 425 thm is wrong. The THM 425 was a front wheel drive trans used in the Olds Toronado and Cadillac Eldorado. Also used in 1973-78 GMC Motorhome.
Old 10-17-2007, 02:39 PM
400 yoke
Now, that is pretty interesting.
Old 10-19-2007, 11:39 PM
well guys i need some infor. i took my bolt on yoke off and it has 31 spline and one flat spot i see that they say 32 spline and then i see 15 on one side of the flat and 15 on the orther side and i see counter bore yokes so would a 400 slip from any 400 work are they all the same what is the best way to go
Old 10-22-2007, 03:38 AM
400 Yoke
You have a 32 spline yoke. If you need to buy a yoke or have questions about it, these guys at Denny's Driveshaft can help you out. About a 1/3 of the way down the page of their site is what you need. Give them a call.
http://www.dennysdriveshaft.com/html/slip_yokes.html
TH350 driveshaft yoke leaking Jmark Transmission - Rearend 11 08-16-2008 11:38 AM
383 or 400?? KFXrider88 Engine 7 06-13-2006 05:45 AM
Turbo 400 yoke question...? Bumpstick Transmission - Rearend 8 12-25-2005 02:41 PM
400 yoke question TASHAN Transmission - Rearend 2 07-17-2005 08:26 AM
Tubro 400 tailshaft &drive shaft Problem MAD BOWTIE Transmission - Rearend 11 06-19-2005 11:51 PM
