Tuned port injection question??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2008, 09:35 PM
jkingof9561's Avatar
yes am rebuilding my 87 camaro,and am planning on swapping the original 350 engine v-belt block stock bore that already gave everything it had... for a 1991 350 2 bolt main block bored 40 over with hyperutectic flat top piston approx. 10.3:1 compression ratio with 64cc, and dress it up with original tune port injection,and my question is...??? the compression ratio would go up and boost a little more power to at least 10-20hp with a double roller timing chain...??? is it going to be more fuel efficient...???any suggestions...???
Old 05-23-2008, 10:07 PM
Wait a while!
By any chance are you from Posen?
Anyway, yes, a double roll chin will eat more efficiently.
BTW - 57th Posen Potato Festival
Old 05-23-2008, 10:29 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Yes it could be more fuel efficient if you can keep your foot out of it. On the down side though, with 10:1 compression you will need to buy premium fuel for it.
Old 05-24-2008, 08:42 PM
Efficiency goes up about 4-5% for every ratio gained in compression. Fuel cost per gallon goes up about 9% between regular and premium. Just messing with the numbers looks something like this:
If the 8.3 to one engine gets 15 mpg, then the 10.3:1 engine then gets 16.2.
20 gallons of regular at $3.75 a gallon costs 75 dollars and the car goes 300 miles.
20 gallons of premium at 3.95 a gallon costs 79 dollars and the car goes 324 miles.
Dividing all this gobblety gook out; you get a per mile cost of 25 cents with 8.3:1 compression and regular gas, while it only costs .24 cents per mile with 10.3:1 compression and premium gas.
Bogie
Old 05-24-2008, 09:43 PM
My 2 cents worth
Wiki Edits: 3
Bogie
That is if he can keep his foot out of it with the added horsepower.
Old 05-24-2008, 09:48 PM
My 2 cents worth
Wiki Edits: 3
We all forgot to mention the added cost of tire replacement which is so common with horsepower gains.
BBC large port oval head question - 781 JamesRS Engine 4 12-21-2009 07:29 AM
Tuned Port Injection -- Cam Question boneyard Buick Engine 6 06-25-2007 12:51 AM
Fuel Injection Question? (modern car) StevenC Engine 10 04-21-2006 01:51 AM
Tuned Port Injection Harness boneyard Buick Engine 3 01-09-2005 01:16 PM
Exhaust port question NXS Engine 6 01-06-2005 08:05 PM
