TunerCATS issue with Read/Programming - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2011, 01:37 PM
Last journal entry: More information
Hi guys,
I have been trying to get TunerCATS to work for my application. I currently have 2 1995 B-Body PCMs, and I intend on reflashing one of them so it will have an M6 F-body tune (also 1995).
However, when i patch into my PCM, i get the error:
"Invalid Response from PCM"
This happens about 3/4 of the way through reading the PCM. I am using a cable purchased from ALDL cables.
has anyone else had this issue? I have followed all the guidelines set up by TunerCATS -- grounded engine, fresh battery, all programs on computer turned off, disabled internet etc. But still no dice.
I can read the VIN number information -- so i know the cable is working. Any ideas?
The car is a 1984 Jaguar XJ6, with a 1994 Camaro Z28/T56... The harness is from a 1996 Impala SS, but the pin-outs for the OBD connector are the same...
Old 02-22-2011, 02:45 PM
Does "same pin outs" imply that the wiring is the same as well?
Old 02-22-2011, 03:28 PM
i traced the wires from the PCM to the wires in the OBD connector -- the obd1 connector cord only has 3 wires, as opposed to OBD2 which has a couple more.
Since I can read the VIN information, it means the cord is working, right?
Need ECU programming in Nashville garretthes Engine 2 07-30-2008 11:29 AM
Can I get some info on programming? Slimpikins Engine 4 05-21-2008 09:11 AM
The programming of life. JunkYardFrog Off-Topic 1 01-14-2006 08:01 AM
PROGRAMMING HELP Chaz General Rodding Tech 0 04-04-2003 08:34 AM
