Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tuning a 700R4
Thread: Tuning a 700R4
  #18 (permalink)
Old 06-11-2012, 08:23 AM
revspan revspan is offline
Well, the transmission is working fine at part and mid throttle. Unfortunately, at WOT, it still hangs at the rev limiter(5500RPM).
I think that I may pull that limiter chip and replace it with a 6000rpm chip to see if it may shift after 5500rpm. The engine has been dynoed and power falls off after about 5300, hence the 5500 limit that I had in the ignition system.
As I understand, WOT shifts are controlled via valve body......Is this for sure?......is there anything else that could impact WOT shift RPM?
Looking for a knob to turn
Thanks!!!!
