Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tuning a 700R4
Thread: Tuning a 700R4
  #20 (permalink)
Old 07-08-2012, 08:31 PM
revspan revspan is offline
another update
Ok...I have now pulled the governor and added weight.
Before and after RPM shift points
1-2 shift. Was 6000 RPM, which is on the rev limiter. Need to let off to shift
2-3 shift. Was 5900 and stayed right at 5900.
3-4 shift. Was 5900, and dropped to 4700.
So.....I am not sure how I can use the governor to move all of the shift points. Seems that the governor is having a big effect on higher gears. If I continue to add weight, I will lose a reasonable shift point in the 3-4 shift.
Also, I "could" simply lift a little during the 1-2 shift, but I plan on a nitrous shot that will rely on a micro switch detecting WOT, so lifting isn't what I would like to do.
Really looking for some ideas here... Thanks in advance.
