1. TV cable should be 100% pulled out at max throttle, controls operating pressure as well as shift patttern. Very important to have it right.
2. With the 4.30 gear the governor is turning alot faster at a lower speed than it was designed for with a low to mid 3's ratios. You'll want the lightest weights you can find and springs that will keep the valve from being pushed in too soon. Take the Garage tour: http://www.youtube.com/watch?v=cZIhuocG2ig |
the carb is a holley 4150 with a kit from Bow Tie Overdrives.
I just ordered a "Corvette" Governor and will take it apart and weigh the parts, reassemble and see if I can get the shift RPMs up. As for the hanging RPM, you may be right, because I really have to mash the throttle for it to rev up, and I may be pulling the cable too far. Here is a question for someone...... If the governor is not calibrated properly(engine speed too low), can the TV force the tranmission to generate a higher RPM? In other words, if the governor isn't properly tuned, does this limit the transmission speed in all conditions? Thanks for the comments so far..... |
Simplified: The governor dumps presssure, when then centrifical force swings the weights out the valve is pushed in blocking off fluid exhaust passages. This causes fluid pressure to "back up" and puts pressure against the shift valves in the valve body and they shuttle against their respective spring pressures thus opening passages for fluid to apply the various clutches and band. You can makes some changes with the governor but with limitations.
Once the gov. valve is 100% in the control action shifts to the valve body. Last edited by regguy1; 03-12-2012 at 04:10 PM. |
Thanks for that explaination....it helps in understanding what is going on in the transmission.
Anyone replace a governor that is forcing shifts at 2500rpm and direct replace for a "corvette" governor? Wondering what could be expected. I have seen a few pictures of them, and it looks like they are simply lightened up somewhat to reduce centrifical force. |
Correct, the weights are lighter. You will probably see a 1/2" hole in the outer heavy weights and perhaps lighter springs betweem the Lg / Small weights. This might give you some small change but probably nothing major.
A photo of a corvette style governor. Please keep in mind that a matching valve body on a vette is calibrated a bit different for this design of governor.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
wow. Compared to the weights that changed in the tuning kit I have, the changes to the outer weights is HUGE. I weighed the inner weights in my stock governor, and they were 0.45oz. The kit I have as weights that are 0.50, 0.45(stock), 0.35, 0.25, and 0.20oz. It will be interesting to compare the mass of the outer weights.....I bet it will be a lot compared to the small changes in the inner weights.
With this, I am hopefull that I can get the shift points up where they need to be. Unfortunately, I have the truck at the interior shop now and can't make any adjustments. Thanks again for all of the information! This site rocks! |
Well, I installed the medium weights and the lightest springs and definitely had an impact in mid throttle response. Actually, under light throttle, the shift points may be a little high, as the trans will now rev to roughly 2800rpm at very light throttle. With a little tuning, I am sure that I will be able to get the mid-throttle shift point where I want with the adjustment kit that I have.
During the one full throttle blast that I did, the transmission downshifted and then proceeded to run right up to thye 5500 RPM rev limiter and hang there until I let off the throttle, at which time it shifted fine. Any ideas? I do have an aftermarked good quality dipstick, but was wondering if fluid level could impact this. Not sure where to go as this really needs to be worked out. Thanks |
let us know the final springs and weights alone with the results.
thanks, ROGER |
if there still advabile get a tpi 350 governer from a f body camaro or trans am they shift about 200 rpm lower than the vette governer the tpi 305 wot shifts around 4800 the 5.7 shifts about 5200
This might not help. Made a chart after calibrating my 85 c10 with a 3.73 rear and th350c. 1st 3.08 number/ 2nd 3.73 both 28" tire.
B&M governor calibration kit for WOT.....AN APPROXIMATION!! GM#24202127 = 4400 rpm Blue&Yellow 2 & 3 = 4900 rpm C10 tried good torque jump to 2nd at 4300 GM#24202117 = 5000 rpm Blue & Yellow 4 & 3 = 5100 rpm 4500 chirp 2nd GM#24202122 = 5200 rpm Blue & Yellow 2 & 5 = 5300 rpm C10 tried revs out till done at 4700 Blue & Yellow 5 & 3 = 5500 rpm Blue & Green 4 & 5 = 5600 rpm c10 revs 5000 full pull, hard kickdown Blue & Green 3 & 5 = 5600 to 5700 rpm with 3.08 and 4700 with 4.10 s10 v6 +500rpm from stock Last edited by spinn; 05-27-2012 at 07:06 AM. |
is the 700r4 governor the same as a 350 ?????
just thought they were different ? thanks, ROGER |
| 427 BBC tuning help | b00tz | Engine | 20 | 01-09-2012 05:07 PM |
| A lil tuning help | bodydroppedsquare | Engine | 3 | 06-02-2008 09:49 AM |
| Tuning a 350 TBI help?? | NOok | Engine | 10 | 07-24-2006 06:37 PM |
| What are the parts in a 700R4 2-3 TransGo shift kit 700R4 2-3 | AngliaBob | Transmission - Rearend | 3 | 04-23-2005 11:25 PM |
| tuning help | ranger | Engine | 0 | 03-16-2005 07:12 AM |
