Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tuning edelbrock carbs
Old 07-31-2002, 03:20 PM
dmorris1200's Avatar
dmorris1200 dmorris1200 is offline
doesn't play well with others
Post
Sounds like she may be running lean and the added load when in gear is bringing the idle down. Not for nothing but I recently bought an Edelbrock carb for my stang. Right out of the box the float was sticking, she stumbled on hard lefts and had a dead spot off the line. I took it off, put it back in the box, and made the store take it back. I opted to pay the extra and got a Holley Street Avenger instead. I've used nothing but Holleys for twenty years and I guess I'll be using them for the future as well. I'm going to try and post a shot of the new carb in my photo album, I like the features of the Avenger carb. Tunable secondaries and no more power valve blow-outs. Good luck with yours, I would start with richenning her up a bit and see what she does, recheck timing, and make sure there's no vacuum leaks. See if you can improve it by adjusting the air/fuel screws on the front of the carb before you go rejetting.
BUILT FORD TOUGH
