tuning a fuel injected motor - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2006, 03:20 PM
all show, all go with a 383
I have a 73 nova with a 383 stroker with fuel injection, computer in car is a Bigstuff 3 ecm. I recently left a post similiar to this but now I have a few more questions. I was working on making the motor fire up instantly after turning key, instead the motor cranks for a second or two.
I talked to one guy and he said to increase the injector pulse width during cranking, I did that and it helped a little but the motor still cranks longer than normal. It doesn't matter if it is cold or warm, or if the motor has been running for a while. It cranks longer than I think it should. I remember with the carburetor on the motor, it would fire up really quick. All the parameters of the motor can be adjusted through the ecm.
Does anyone know what else might cause the motor to crank longer than neccesary?
timing is not far advanced, maybe about 12 degrees at idle.
fuel pressure is about 55 psi, have 55 lb injectors.
If you need to know anything else about the setup, please let me know, so I can help you help me.
need to get this fixed before the carshows start
thanks
Dan
Aftermarket EFI ? x007 Engine 61 02-08-2012 10:38 AM
1960 corvette rochester fuel injection ratlover Engine 2 09-27-2005 05:43 PM
93 Suburban fuel pump sabino56 Engine 8 09-10-2005 02:54 PM
Fuel Tank Installation Plumbing Questions Doc68 Engine 9 01-05-2004 06:20 PM
Can Fuel Injected Cars Shoot Exhaust Flames? wendog Engine 6 11-25-2003 12:41 AM
