tuning help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2005, 07:12 AM
ranger's Avatar
tuning help
i have a 92 mustang gt w/ a 306,speed pro pistons,.038 head gasket,0 deck height,gt40p heads,ported and polished w/ 1:94 intake valves,1.7 rr,e-cam,75mm egr plate,70mm t/b,73 c&l mav.march cold air system.running a stock a9l computer.my problem is i can't get the car to run under 2800 rpm until it gets warmed up. then it idles fine . is this because the computer needs the timing and fuel curve reset or what. time is set at 17 degrees
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Tuning EFI and large cams TurboS10 Engine 0 03-12-2004 09:07 PM
what first? advance curve or carb tuning? dirtydave Engine 3 11-07-2003 04:42 PM
Fine Tuning Gadgets Silver_Camaro Engine 2 10-14-2003 07:37 AM
tuning carb satanic mechanic Engine 13 01-01-2003 01:27 PM
