Tuning MSD Mechanical Advance Distributor
Engine:
385 sbc Scat 4130 bottom end Scat I bean w/ 7/16 bolts Probe SRS .040 flat tops with reliefs, block decked to 9.08"s Standard oil pump with cheapy Moroso with wings no windage Solid roller: Comp Xtreme Energy XR280R Duration 280/286, Lift .570/.576 (with 1.5's, I've got 1.52 comps.. Dart 230cc Iron Eagles ported with a Air gap single plane and Holley 850 dp I built this thing at the local CC and it's all tight, right and new My question is I've got a MSD pro billet non vac distributor and want get it dialed in. I'm running 24*-26* idle timing per this "run on" thread post #16 New built 385 SBC Dieseling The dist has the 21* stop in it now and two of the heavy silver springs in it per factory MSD settings. So I'm running like upper 40 something all in timing. On the dyno with the same stop and springs it pulled 489 with 38* all in.. What I'm thinking is going all in by 3000rpm with a light silver and a light blue spring combo and using the largest stop I have which is 18*.. That will still have me in the 40* range.. What I need is a 12-14* stop to put me around 38* with 25* off idle.. Does this sound right? Can I use a tiny washer to make the 18* stop larger while making it a 14*er? |
Oh and I'm guessing I've got a 3500 stall in the TH350 and 4.56 out back..
Here's a quick little vid to give you an idea http://www.youtube.com/watch?v=_KZp_rmUzVM |
Just found this little bit of info. What do you think?
http://www.4secondsflat.com/MSD%20Di...r%20Tuning.htm |
I have a motor similar to yours, with a bit more duration (248/254). I feel your initial timing is excessive. I have mine a 18 with the 18 stop all in at 3000 making over 550hp. Idles at about 900.
Also, that cam may well want more initial timing, but again it's try and retry to see what the results are- there's no set law on how much initial timing or how soon the total is in by, when dealing w/ignition timing. Too many variables. But high 40º total is way too much, as you know. I'd shoot for somewhere between 34º and 38º, depending on the heads, fuel, etc. Quote:
Good luck. Last edited by cobalt327; 05-13-2011 at 02:06 AM. |
If you want you can stick something in the end of the slot to shorten the travel further, while using the biggest bushing in the kit.
This will allow more initial at idle. Something in the 20-26deg zone should work well) Try it locked out, first, just for grins. +Make sure the amount of vacuum advance is not excessive (10-15deg max @ high manifold vacuum part throttle) and that it comes in and out at the right rate. |
| vacume advance or mechanical advance? | BigBlockT | Engine | 1 | 06-08-2009 07:05 PM |
| Total advance, initial, mechanical and vaccum advance Can anyone break it down Please | Brawler | Engine | 2 | 09-07-2007 07:25 PM |
| Distributor infinite mechanical advance | Tabdown | Engine | 9 | 03-11-2005 07:02 PM |
| Mechanical Advance settings...... | black66 | Hotrodding Basics | 12 | 08-28-2004 02:35 PM |
| how much mechanical advance does a stock distributor have? | smlblcks10 | Engine | 2 | 11-21-2003 07:25 AM |
