tuning prob 750 blow through demon - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2010, 06:21 PM
hi guys i have a cleveland 351 twin to4 turbo set up, i bought a 750 blow through demon , I am having a bad surging problem under boost I was wondering if you guys have seen this before and could help me at all, thanks
Old 06-14-2010, 03:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Couple thoughts:
Can you describe this "surge" a bit clearer? Like under WOT, or just accelerating w/positive boost, top of the rev band, lower down?
Is the carb in a box or are you using a hat? What's the fuel system? Pump/regulator type and psi setting? Size of lines, type fuel, filters?
Any possibility this is valve train related- as in float/lofting valves, too weak springs, etc.?
What is the ignition system?
acceleration flat spot in carb. corvettetonybone Engine 17 04-13-2013 09:31 PM
Stock 350 Road Demon Tuning smartparts312 Engine 27 11-13-2009 01:15 PM
Demon tuning help Deman625 Engine 1 08-16-2004 07:47 PM
770 Holley street avenger or 750 BG Street Demon Shawn Horan Engine 8 04-03-2004 09:23 AM
demon carb tuning joeyg329 Engine 3 03-12-2004 07:05 AM
