Tuning questions. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2006, 12:13 PM
comet boy's Avatar
When all else fails burn it
Last journal entry: more hiding stuff
Tuning questions.
The vehicle in question is a friends 81 chevy truck with a stock 350. the problem is that when he drives it stumbles and backfires through the carb. so I brought it over to my shop to look at it. when I started it to pull it into the shop it wouldn't idle. it kept reving higher and higher until I shut it down. I thought the linkage was stuck so I opened the hood and check but it was all clear. so then I went to start it again and it had a huge backfire thru the exhaust. it sounded like a gun shot this was followed by emense amounts of black smoke. SO my geuss is the problem lies with the timing but I don't know what to check and was wanting your guys opinions on what to check first.
okay I have an update. I went out and started it back up. It fired right off and was running pretty good. but it was really loud so I checked and I blew the side of the muffler out and that was what the loud noise was. SO I know a clogged cat. can cause drivability issues. But could a clogged muffler cause all the problems that were happening before. If not why did the muffler blow out?
Old 06-30-2006, 02:35 PM
DoubleVision's Avatar
I had the same thing happen years ago in a 79 Malibu I had, this is usually caused by flooding on start up due to the primaries leaking down on a Q-jet carb, or just flooding period. The raw gas and fumes get trapped in the muffler and can`t get out, a good backfire ignites it and boom! Ever burn a high mileage muffler in a fire? 9 times out of ten, it`ll go off like a shotgun several times before it burns out the fuel vapour.
Old 06-30-2006, 02:51 PM
spinn's Avatar
combustion in the exhaust
i think lean mixtures can cause this too, ,especailly with retarded timming.
Old 06-30-2006, 05:08 PM
comet boy's Avatar
yea I figured out why I blew out the muffler but I was wondering what could be causing the drivability issues. it has a demon carb. Which vaccum port is the vaccum advance supposed to be hooked to?? the ported or continuous?? or could the problems be caused by something completey different
Demon Tuning by cuda66273.... mstngjoe Engine 4 03-13-2006 06:46 AM
plug fouling and other tuning problems slow ride Engine 3 08-04-2005 07:35 PM
Success in tuning BG Speed Demon 406chevelle Engine 2 06-26-2005 09:44 PM
A few questions.... Meangreen Engine 13 05-12-2004 05:55 AM
Holley tuning questions. F-1Rodder Engine 16 06-14-2003 01:20 PM
