Tuning tunnelram twin Edelbrock 750's - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-05-2013, 10:12 PM
Fang16's Avatar
Last journal entry: Project change
Ok, down to tuning the twin Edelbrock 750's on my Edelbrock street tunnelram. I have the carb manual from Edelbrock but they just talk about one carb. My question is: how close is this to being correct for tuning twin carbs? Can a guy still go by they're recommendations? I'm thinking that with the twin carbs set at the factory jetting and needles it's gonna be way rich. Where is a good starting point? I just got my LM-2 AFR meter and need a good starting point on the jets and needles.
355 CI
11:1
Comp cams XR292R
Duration @ .050 254 intake 260 exhaust
Lift .582 .588
Edelbrock TR1YX tunnel ram 2 x 750 Edelbrocks
Ported double hump 2.02/1.60 3891462 64cc heads
700R4/3500 stall
3.90:1 ford 9"
Race weight 3257
80% Street/ 20% strip car
Old 04-05-2013, 11:06 PM
spinn's Avatar
The ed 750 on a single manifold is rated at 1.5 " mercury. A dual carb tunnel ram would pull at .5" mercury. That lands your total cfm around 850.
A little over carbureted , but in the ball park for tunnel ram application goodness.
I would start near the baseline. Refer to the rod/jet diagram after that to see where to go.
Old 04-06-2013, 02:21 AM
vinniekq2's Avatar
I ran 2x750 cfm on a flat tappet 355.I played with the metering rods a little,they worked well.( mine were carters)
edelbrock tunnelram blazinlow Engine 4 12-06-2012 03:16 PM
Edelbrock 750 tuning GCD1962 Engine 34 04-16-2008 06:03 PM
Edelbrock TRI tunnelram chevyhotrod Engine 3 07-23-2007 02:12 AM
Still tuning Demon 750 406chevelle Engine 41 09-05-2005 11:07 PM
Need help tuning my 750 speed demon 406chevelle Engine 31 09-13-2004 06:28 AM
