Tuning with a wideband o2 (LM1) - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2004, 12:40 PM
MEAN_SBC's Avatar
I recently purchased an Innovate Motorsports Wideband AFR system, and was lookin for pointers on tuning with it. I figure the numbers I need to look at for NA usage should be around 13.2:1., and on nitrous around 12.0:1. Also I'm guessing that it should idle, and run part throttle as close to stoichometric as possible, correct??? This is all on a carb'd 383 chevy.. Thanks!
Old 10-10-2004, 06:26 PM
New Member
Check over at thirdgen.org, they do a lot of tuning with the WB O2 sensors.
HotRod55Man
