Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - tunnal ram tips?? sbc s10
Old 11-07-2011, 06:18 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
On mine I run two 450's with the power valves blocked off... Ran Like a bat out of H*** !!!!!
Two 600 is 1200 cfm's.... That's two much cfm's for a small block Chevy.. Remember a sbc usually run's best with a 750 Or a little bigger carb..That's 750 cfm's... You have 1200 cfm's.... Get two 450's and block off the power valves... You should see a big difference..... Also if you don't have a good msd to fire everything forget trying to get it right.... I Bought a msd kit from jegs for $540.00 or so.... Best money I ever spent...
http://youtu.be/y9XzfFhYrZI
ID:	59526   Click image for larger version
