tunnal ram tips?? sbc s10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2011, 10:53 AM
i have a 1985 s10 10.1 cr 350, 461 double humpers, eddy's performer cam very healthy motor, im not looking to make it run better as long as it runs as good, this is going to be my "two lane black top", th350 trans w 2000rpm stall, 4.10 gears, i have two 600 eddy's i plan on useing at first sence i already have them, mayb recalibrate them any ideas.....
Old 11-06-2011, 01:00 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
I have 2 Holley 340s and they make my engine run rich. 600s will only be worse.
Old 11-06-2011, 05:35 PM
You're gonna find a bunch of tunnel-ram haters , for what it's worth, they can be setup to run very well on the street , do some searches & read up on tuning, maybe get some carb tuning books to help you understand what's going on, but it's doable. + the really look cool , IMHO
dave
Old 11-07-2011, 12:18 AM
I love my tunnel ram, you just have to make sure the rest of the car is setup for it. They don't start making power till 3000 RPM. Living that high in the power band isn't easy but it can be done. It would be much easier if it wasn't an automatic.
My car gets so much attention and its mostly due to the Tunnel ram.
I drive it on the street and its does a pretty good job. I do need to do something about the rear gear ratio. Its not right and I'm not in the right RPMs like I should be unless I shift manually.
Old 11-07-2011, 08:28 AM
lg1969's Avatar
Google "Tunnel Ram 406"
What made you to decide of getting 600 eddy's for your TR set up?
Old 11-07-2011, 10:13 AM
lg1969's Avatar
Personally I do not like the idea of using two 600 CFM eddy’s carbs on the tunnel ram on 350 motor that is street driven. There is so much air a motor can deliver depending what RPM you are working with. After that it’s a waste of effort to produce more horsepower. You go overboard and the motor will not perform the way you want. In fact the motor will run like a dog. It will bog off the line and lean backfire, smell of raw gas. Difficult to start. Lousy low end throttle response because over size of the ventures on the carbs. Unless your planning to rev the motor to 8000- 9000 RPM then two 600 CFM carbs will do the job. A pair of Holley 390 #8007 would be a better choice.
Old 11-07-2011, 02:54 PM
Closer look at my engine
Old 11-07-2011, 03:05 PM
lg1969's Avatar
http://www.hotrodders.com/gallery/sh...cat/500/page/2
Old 11-07-2011, 03:40 PM
lg1969's Avatar
Jake, what type of tunnel ram you are running? The plenum in my TR is half the size I'm using.
Old 11-07-2011, 04:18 PM
id thought id go ahead and use the two 600's i have till i get it closer to being finished, its going to be street rod and its a working progress, later i plan on gettin 450's do some fine tuneing, it will take time to work out all tha cinks but we we'll get there..but all all the info is great and im love'n the pics to.
Old 11-07-2011, 05:18 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
On mine I run two 450's with the power valves blocked off... Ran Like a bat out of H*** !!!!!
Two 600 is 1200 cfm's.... That's two much cfm's for a small block Chevy.. Remember a sbc usually run's best with a 750 Or a little bigger carb..That's 750 cfm's... You have 1200 cfm's.... Get two 450's and block off the power valves... You should see a big difference..... Also if you don't have a good msd to fire everything forget trying to get it right.... I Bought a msd kit from jegs for $540.00 or so.... Best money I ever spent...
http://youtu.be/y9XzfFhYrZI
ID:	59526   Click image for larger version
Old 11-07-2011, 05:53 PM
Its an edelbrock tunnel ram
Old 11-07-2011, 06:58 PM
F-BIRD'88's Avatar
Yada Yada Yada
The eddy 600's will work fine on your t ram. The are not too big.
The eddy carbs have a secondary air velocity valve that automaticly sizes the carb(s) to engine demand.
You will want to get the jet /metering rod tuning kit for your carb model
The distributor timing curve will need tweeking.
A afr gauge/meter -O2sensor makes tuning and dialing it all in a snap.
The tunnel ram manifold needs time to "warm up" before street driving.
The 2000 stall converter is fine as ling as the cam is mild.
The 4.10's are just right.
You do not need new carbs.
Max fuel pressure at idle 5.5psi.
Old 11-07-2011, 07:06 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Depends on the SBC, a 750 is too big for most mild mannered to slightly modified SBC's, let's say 375 Hp and less. For those motors a 600 cfm carb is a much better choice. Crisper throttle response and better all around driving.
Old 11-07-2011, 07:11 PM
Yea!!!! but not two of them !!!!
I didn't think I had to say a HOT SBC !!!! Since this is a Hot rod site..But I guess I didn't explain myself good enough..
And he does have a little hotter then slightly modified sbc..
Sorry.... I forgot why I don't try to answer on this side of the forum... Now I'm starting to remember now..
welding tips/ mixing featherfill tips tech69 Body - Exterior 1 04-16-2011 02:15 PM
Where to get tips for HF gun Tomlowe523 Body - Exterior 0 01-31-2010 10:11 PM
2-4 tunnal ram still tryin green monzter Engine 14 07-19-2007 09:46 AM
can my 350 handle the 2-4 tunnal ram it has green monzter Engine 17 07-17-2007 10:29 PM
Carbs on Tunnal Ram Spamb0 Engine 1 02-04-2003 09:08 PM
