Tunnel Ram - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2007, 05:49 PM
Tunnel Ram
I have a s10 truck that i have restored with a small block 355. Has anyone had any experience with a good cam to run with a tunnel ram intake setup. This is mainly a show truck so would like that turn your head sound.Any suggestions?
Old 08-13-2007, 06:53 PM
techinspector1's Avatar
Wiki Edits: 326
http://www.hotrodders.com/forum/sear...archid=1246755
Old 08-13-2007, 09:39 PM
cams
hunt i have a small block 350 tunnel ram and had the same question and i finnally went with the new voodoo cam with 501 lift don't know how its going to run but one thing alot of people told me was to pic a cam i would like and use the carbs to make the engine sound a little ruff. dont ask me if there right im still in the process of building my 23 t good luck
Old 08-13-2007, 10:26 PM
DoubleVision's Avatar
The carb has little to do with how it`ll sound, it`s job is to deliver the air/fuel mixture, it don`t know or care what size the engine is. The cam is what plays the role in the lopey idle sound. You can have a stock 305 with a comp cams 268H cam and it`ll lope, sound mean as if it`ll take anything, but likely won`t take a stock 350. The same cam will also lope in a 350, in a 400 it`ll idle smooth. You could stick a tunnel ram on a stock small block as long as the carbs were in the 390 range, with the correct tuning it wouldn`t lope. In the past I`ve seen stock engines with a knocked off exhaust that loped like it had a huge cam.
Old 08-14-2007, 02:00 PM
Thanks for the info
Good luck, let me know how it turns out.
Old 08-14-2007, 02:29 PM
Can you tell me what the lobe centers are?
Old 08-14-2007, 02:37 PM
Thanks for the information. :
tunnel ram set up advice/opinions needed please pal Engine 22 03-22-2013 03:53 PM
Tunnel Ram on 383 Stroker Nitromethane Engine 6 02-25-2011 08:06 PM
Tunnel Ram information xntrik Engine 79 08-17-2008 02:15 PM
Tunnel ram carb selection baddbob Engine 2 07-09-2007 08:05 AM
Big Block Tunnel Ram 2X4 Question 74NovaRat Engine 12 01-28-2005 01:22 PM
