tunnel ram - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2011, 06:01 AM
blazinlow's Avatar
tunnel ram
My sbc with dual 450's has a dead spot off idle. I am running progressive linkage off the front carb. Is it better to run off the back carb, would larger squirters help
Old 05-21-2011, 06:17 AM
I run duals and use the rear carb. for the primary. A short test is to run off each carb. one at a time to see if one particular carb. has a problem.
The reason for running off the rear carb is that the front two barrels are the closest to center of the motor than the front two of the front carb.
Old 05-21-2011, 06:28 AM
BOBCRMAN@aol.com's Avatar
Also run as much initial ignition advance as possible.
Old 05-21-2011, 06:31 AM
blazinlow's Avatar
I give it a shot, if it works , it may be an SOB to change the progressive linkage. What makes it weird, is that i only had a slight problem till I bought new 450's
Help!! Sbc Tunnel Ram forkliftdr Engine 5 05-21-2011 06:34 AM
sbf hi ram tunnel ram 72fordlb Engine 9 04-13-2009 04:15 PM
Tunnel Ram on 283 58lincoln General Rodding Tech 26 01-20-2009 05:43 PM
How to -Tunnel Ram sedan_dad Hotrodders' Lounge 0 01-20-2003 09:15 AM
a tunnel ram ? jboxcar818 Transmission - Rearend 1 12-12-2002 03:51 PM
