tunnel ram - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2013, 04:45 PM
tunnel ram
I have a 350 flat tops 64 cc heads has summit 1107 cam in it now. was thinking on putting a weiand tunnel ram on it. Has 2 450 Holley carbs on top I think motor has 9.0.1 compression headers 5speed and 373 gears will this setup work on a street truck s10 not looking for drag truck just car shows hot riding trying to get me a setup for next spring thanks guys
Old 01-02-2013, 05:15 PM
Richiehd's Avatar
JS-70
I had similar setup years ago in a 34 roadster. We cut about 1 inch out of the upper plenum, this brought some driveability to it. Still even a light car the bottom end was weak. It was bad *** though and drew looks everywhere we went!
Old 01-02-2013, 09:02 PM
If I use 15 head gaskets and how much should I shave the heads to get compression up
Old 01-02-2013, 09:18 PM
vinniekq2's Avatar
it would look cool and sound cool
Old 01-02-2013, 09:47 PM
techinspector1's Avatar
Wiki Edits: 326
A 350 with flat-tops and 64cc heads will be about 10.2:1 SCR. Cam and SCR are well-matched in your combination. Use 18 degrees ignition lead at the crank and 18 in the weights, all in by 2800. Edelbrock RPM intake #7101 with 750 carb, (double pumper if stick trans or auto with 3000+ converter, vacuum secondaries if auto with tight converter) 14"x4" air filter assembly, 1 5/8" long tube headers with X or H tube before the mufflers. COMBINATION, COMBINATION, COMBINATION.
Old 01-03-2013, 02:47 PM
lg1969's Avatar
Google "Tunnel Ram 406"
Trash the 450 Holley. The instant you smash the gas peddle. Your car is going into a nose dive, Backfire or stall out. Not to mention pig rich at idle.
sbf hi ram tunnel ram 72fordlb Engine 9 04-13-2009 04:15 PM
Tunnel Ram mcniner Engine 1 04-30-2007 09:05 PM
Tunnel ram OR NOT ?? ss crazy Engine 11 09-09-2003 09:57 AM
How to -Tunnel Ram sedan_dad Hotrodders' Lounge 0 01-20-2003 09:15 AM
a tunnel ram? jboxcar818 Engine 2 12-11-2002 09:04 PM
