Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel Ram 327
Thread: Tunnel Ram 327
  #21 (permalink)
Old 07-10-2004, 08:25 PM
lluciano77's Avatar
lluciano77 lluciano77 is offline
That is true, you are doubling the fuel area. But the flow isn't exactly double for each carb.
Holley most definetly does not recommend using two 390s on a V8. The 390 is recommended for single carb applications on small dispalcement V8s and performance 6 cylinder engines with aftermarket intakes.
If you ever get the chance, take the powervalve gasket out of one carb on a dual carb setup. Let the engine run for a little bit. There will be dew and ice forming. It is because of the over rich condition. The excess fuel does evaporate inside the tunnel ram plenum.
Running lean will not cool things down. Think about it.
