I've got a Chevy Camaro with a 350 bored n stroked to 383, solid roller 3000-7000rpm cam, victor jr intake and victor jr heads... it's primarily used as a weekend bracket racer, n my aim is to make as much power as possible on pump gas so I can still drive it to the track n around town on the weekends - my question is basically this... will the Summit Tunnel Ram kit (Weiand Tunnel Ram with dual holley 4-bbl's) give me quicker ET's than a Victor Jr with 1" carb spacer and a Holley 750 4160 carb with vac secondaries? I'm running a 3500 stall torque converter so the bottom end power issue wont be such an issue.
Also, how much extra power is usually expected from changing to a tunnel ram setup? I dont feel like spending $1000 on body work n new distributor n air cleaner assembly etc if I'm only gonna get about 10hp out of it. Which carbs would you reccomend on a maximum-effort 7000rpm 383? Thanks for any help, n if anyone has a camaro feel free to check out my site and msg board over at CamaroWorld.com. |
i am not a drag racer (yet) and never owned a tunnel ram (yet), but think the HRM carb/intake dyno article showed higher horsepower from a single quad super victor intake with 750 speed or race demon carb(or was it that big-*** holley dominator?) than the summit combo and even more than the higher dollar edelbrock tunnel w/2 650 holleys. Hopefully somebody who knows from real life will answer this quandry. I'm pretty sure that unless your engine can suck the cfm's the tunnel can deliver you can't beat a single quad. the summit combo was by far cheapest of all the combinations at just alittle less HP than the single quad on the super victor. that rag seems to be the one issue i can't find.
Hello.
I have a year old mag that they done a study on this and the best dyno was an Edelbrock tunnel ram with 2 600 carbs. Next was the summitt combo with 2 450 carbs. I think either will cause it to load up a little on the street just because your mainly cruising and not at WOT. But you can make it work. I'll try and find that article and give you the exact specs. HG |
I'm kinda leaning towards getting one of those $530 CNC machined Super Victor intakes and a Race Demon RS carb or get a race carb made by BLP (local guys here in Orlando who do the NASCAR carbs), it'll most likely make more power than any tunnel ram setup for that price... granted it won't stick outta the hood n look all sexy, but it'll definately perform. I'd still be interested in finding out some actual hp numbers for a tunnel ram tho, does anyone have the article bullheimer referred to?
CID x max RPM / 3456 This gives you 383 x 7000 / 3456 = 775CFM this will work on all setups so don't go putting 2 x 750 on your engine. 2 x 400CFM is enough.... |
