Tunnel Ram 454 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2012, 05:39 PM
rambler454's Avatar
Last journal entry: another project
Tunnel Ram 454
okay..i bought a fresh built 454. stock heads and all. my question is what head should i run to boost power with running on pumped gas with a tunnel ram? im putting a good size cam in and over sized hooker super comp ceramic coated crome headers.i've been told the larger intake ports are the wrong move entirely. so im at a stopping point with my motor. i usually port and polish and gasket match everything. help me out tech gods! lol oh and im also running 2 600cfm holly carbs with hilborn scoop.
Old 01-30-2012, 06:07 PM
NOlowrider's Avatar
US Navy-Retired
I ran a my 454 basically stock with a TR. Had a larger cam (Comp XE292 I think) and a 3500 stall. Had the stock 781 heads. Ran great. Since then I have upgraded to a blower, but still loved my TR. It's all in the tuning and gearing.
This is a early pic, I cleaned it up some after this was taken.
Old 01-30-2012, 08:23 PM
F-BIRD'88's Avatar
Yada Yada Yada
The 781 or 049 open chamber oval port heads work very will on street strip 454's with porting and larger 2.19 x 1.88 valves.
Take a valve cover off and look for the casting number.
Old 01-31-2012, 08:38 AM
lg1969's Avatar
Google "Tunnel Ram 406"
How big is the cam? Because too big and the tranny will not shift right because of the vacuum modulator. Not to mention the gears you are running.
I hope they are 355 to 390 for the street. There is nothing wrong using oval port heads. What is the compression? What kind of 600 holley are they?
Old 01-31-2012, 03:04 PM
rambler454's Avatar
the carbs im running are 600 cfm holly.nothing crazy. not double pumpers.and vacuum secondaries. im running a turbo 400. i dont want to but that what i got at the moment. i i guess my rearend is an 8.2.
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 282/282, Lift .533/.533 is what im thinking of running.
Old 01-31-2012, 03:58 PM
lg1969's Avatar
Nothing wrong with the 600VS. Just change the diaphram top cover where you could connect a balance vacuum line between them for uniform secondary operation. Just hope you do not blow the rear.
Old 01-31-2012, 06:22 PM
rambler454's Avatar
what rearend would you consider? 9'' 411 ect?
Old 01-31-2012, 06:29 PM
lg1969's Avatar
9" 411 is great. You mention 8.2 on your post. I was confused
Old 02-02-2012, 01:51 PM
(aftermarket) Ford 9, Dana 60, GM 12bolt and Ford 8.8 are all more than acceptable. Whichever one fits in your truck with the least work. Somewhere around a 3.89:1 - 4.11:1 rear gear.
You might want to run a Vacuum res if you're running a brake booster (or a hydroboost style unit)
Old 02-02-2012, 04:45 PM
1971BB427's Avatar
I ran that same spec cam in my '71 Camaro with a 11:1 CR 427, and tunnel ram with twin 600 cfm Holleys. Drove it both street and strip and it worked well for both. My heads were the old style 961 oval port small chamber with just some port matching and polishing. 3.73 gears.
Since I retired it from racing I went back to an old Edelbrock Torker intake with single 750cfm, and lowered the CR to 10:1, and gears to 3.42 for daily driving.
Old 02-02-2012, 05:07 PM
rambler454's Avatar
im running it in a 64 rambler american 330.
Help!! Sbc Tunnel Ram forkliftdr Engine 5 05-21-2011 06:34 AM
Tunnel Ram hunt345 Engine 8 08-14-2007 02:37 PM
Tunnel Ram 69 chevelle SS Engine 2 08-07-2003 09:06 PM
TUNNEL RAM SET-UP rooster Engine 2 02-19-2003 01:08 PM
How to -Tunnel Ram sedan_dad Hotrodders' Lounge 0 01-20-2003 09:15 AM
