Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel ram bogs
Thread: Tunnel ram bogs
  #21 (permalink)
Old 04-20-2013, 09:31 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Your timing is not locked out. You do not need or want a timing curve.
You want full fixed timing 36deg at idle and 36deg at rpm.
Eliminate the timing curve. This cam need fixed locked timing to get a clean launch.
Then remove the carb spacers. Mount the 750 carbs direct on the intake manifold.
This is where you start tuning..
before you reported good "drivability and throttle response . Now the story has changed. WHY?
