Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel ram bogs
Thread: Tunnel ram bogs
  #26 (permalink)
Old 04-20-2013, 11:20 PM
Fang16's Avatar
Fang16 Fang16 is offline
Last journal entry: Project change
Originally Posted by F-BIRD'88 View Post
lock out the programable tming curve. You do not want any timing curve at all.
36deg full time. 36deg at idle that does not move with rpm.
Then reset the carbs idle speed and idle mixture once the timing is corrected.
DO NOT JET based on spark plug appearance.
or colour. All you are looking for on the plugs is for excwessive heat and or detonation, NOT Colour.
You jet for power. (Drag strip MPH) Go back to stock default jetting It was not that far off.
You are likely WAY TOO RICH.NOW.
You will not get a clean idle or throttle response until you have corrected the idle timing.
This cam wants locked out full fixed timing. Not a tiiming curve. Eliminate the tiiming curve.
You spark plugs are likely fouled now. Do not use a cold racing plug.
DO not evaluate the throttle response in park. The only throttle response that matters is when driving.
The engine must be warmed up first.
Go back to a .113 pri jet and .073x .047 rod pri and 4" step up spring. use a .110" sec jet.
Then try a .113" pri jet and a .073x .042" pri rod and a .110" sec jet.
You ar4e jumping up way to far on the jetting all at once.
It was not that far off before.
Fix the exhaust gasket leak. (that is giveing you false lean AFR readings)
What heads are on this motor? what spark plug?
Answered before ur edit about jetting so will do it here. Ported double humps, 2.02 and 1.60. AC 45ts plugs at .035. Exhaust leak, don't think so but it pretty loud so hard to tell. The gaskets all look good. how would I find a leak if I can't hear it over the pipes?
