Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel ram bogs
Thread: Tunnel ram bogs
  #36 (permalink)
Old 04-20-2013, 11:15 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
When you do a AFR trace and post it. could you add information to the data trace showing, approx relative throttle position and or manifold vacuum and trans gear.
So I kow what you are doing at any one time beyond just time AFR and engine RPM.
Note pad will allow you to edit.
