Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel ram bogs
Thread: Tunnel ram bogs
  #46 (permalink)
Old 04-21-2013, 12:45 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is online now
Yada Yada Yada
what distributor model? vacuum advance?
The distyributor cap/rotor/mag pick up phasing alignment must be within spec or the spark will scatter.
The timing retard box effects the distributor phasing..sometimes with a bad result. ( misfire, cross fire, scatter)
mag pick up wire +/- phasing. Some times it has to be reversed.
