Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Tunnel ram bogs
Thread: Tunnel ram bogs
  #52 (permalink)
Old 04-21-2013, 11:06 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Did you fix the carb float/flooding/ accelerator pump fuel leak problem?
get the floats set correctly.... first. I don't know why these carbs do not have a sight glass to see the fuel level
in the bowl. They are very sensitive to float setting and fuel pressure.
Remember.... the air cleaners in the blower scoop will have a effect on the carb tune.
They tend to restrict the top end horsepower, but tend to smooth out the air flow into the carbs.
They also affect the action of the secondary air doors. You will have to experiment to find what works best.
Much like the QJET carb these carbs take a bit of patience and tuning to get them right.
Once dialed in they work very well.
